1990 Accord EX Brake Light issue
Hello,
I just bought this Accord for $900! It's in really good condition with 167k miles on it. There are a few minor things wrong but overall I'm really happy.
The main issue I'm having is the brake lights. The middle light in the rear window & the passenger side brake light(s) don't get bright when you step on the brake. The passenger side brake lights, on the trunk and to the right of the trunk, light up fine but don't get brighter when I brake. The driver side brake light works fine.
I had trouble finding the fuse for this since it isn't labeled on the fuse boxes or in the chilton manual I have. After some research I nailed it down to the horn fuse under the hood. Is this right? It says it's a 20amp fuse, but someone put a 25 amp fuse in there. This tells me there could have been some issues with something on that circuit in the past and someone tried to bypass it using the 25amp fuse.
So anyways, the fuse is fine, the bulbs are all replaced. What else?
I've read somewhere about a Brake Light Control Module but I can't find any documentation on this, only a couple posts of people talking about it. Is there one? Where is it located?
I'd appreciate any information that could help and troubleshooting tips. Thank you!
I forgot to mention that the Brake Lamp light on my dash is on.
Looking at the schematic in my Chilton's, I see that the "Right brake light failure sensor" is tied into both passenger side brake light and the high mount brake light. Do you think this sensor could be bad and cutting the ground to the lights? Where is this located?
GoNASA111
12-06-2013 05:33 PM
victorywhity
03-24-2011 09:37 PM
wize_n
10-10-2008 06:49 AM
