Sponsored by:
Sponsored by:
2001 accord 2.3l vtec main bearing bolts torque
Old 05-12-2014, 10:37 PM
hondaddy's Avatar
Default 2001 accord 2.3l vtec main bearing bolts torque
Hello. I searched but could not find a post for the Main Bearing Caps/baffle torque specs. Anyone??? Thanks
Old 05-12-2014, 10:44 PM
Your thread has been moved from the DIY section. Please do not post help questions in the DIY section.
Old 05-13-2014, 03:00 AM
If you are talking about the 11mm bolts you first tighten them to 22ft/lbs then 58ft/tlbs
In this order:
10 4 2 6 8 This is the transmission side of the engine
7 5 1 3 9
the 6mm bolts are the same order but 8.7ft/lbs.
joenintiesc
04-14-2013 07:29 AM
blahblahfoo
02-19-2012 12:00 AM
oma93
02-06-2008 12:43 AM
Hop
05-18-2007 12:47 AM
MALSR
09-26-2006 08:58 PM
Quick Reply: 2001 accord 2.3l vtec main bearing bolts torque
