Rear brake lights on 1999 accord
Old Jan 6, 2012 | 01:05 AM
wendy's Avatar
Default Rear brake lights on 1999 accord
Both rear brake lights stopped working. What could be the problem/what do I check?
Old Jan 6, 2012 | 08:17 AM
Moved your post to correct forum for help.
Fuse 30 in under hood fuse box controlled brake lights on earlier models. Check this first.
Are you having problems getting shifter to shift from P to D? If yes, then look for brake light switch on brake pedal to be stuck in open position (does not extend when brake is pressed).
Sometimes a good dose of WD40 and manual exercise will fix. Otherwise a new switch is indicated.
Mr. 99
Feb 6, 2019 04:56 PM
Brad1986usaf
Jan 16, 2012 06:27 PM
Will.bartlett
Feb 27, 2010 08:44 PM
dcmazz
Feb 16, 2010 08:34 AM
Metro
Jan 13, 2009 02:53 PM
