1992 accord Runs & Dies
my 92 accord will start up,run for 4 second, then dies down then slowly out. The car has a new battery, spark plug,n wire,also a main relay, check all fuse timing belt, vac. hose, alternator. could not find the problem.Can someone help me PLZ
First you should check for codes, jumper the BLUE 2 pin connector behind the passenger side kick panel, then turn on the key. Watch the CEL for flash codes.
See if you can keep it running by spraying carb cleaner in the throttle body, that would indicate fuel flow/fuel pump problem.
With the key ON check for power at the Black/yellow wire at the distributor plug.
Accord Pete
01-31-2010 02:50 PM
