Sponsored by:
Sponsored by:
1993 honda civic front brakes locking up
Old 10-21-2014, 03:02 PM
lovely4's Avatar
Post 1993 honda civic front brakes locking up
hey my 93 honda civic front brakes keeps locking up on me, i did everything from changing the brake pads and bleeding them, can some one please give me some extra tips please.
Old 10-21-2014, 05:40 PM
When changing the pads, did you lube the caliper slide-pins?
How about the pads themselves wedging tightly in the caliper-bracket? This can cause them to not release.
How about brake pedal-height adjustment? Maybe the master-cylinder piston doesn't move back to the proper position, opening up the vent to the reservoir. When the calipers (& fluid) heat up, the fluid is trapped so as it expands it applies the brakes.
Another thing that's admittedly kinda unusual...
I've heard of cases where the rubber brake hose deteriorates inside, with a little flap of rubber acting like a "check-valve" of sorts. Then when the caliper & fluid heats up, the fluid cannot expand back into the reservoir so that causes the brake to apply itself.
Old 10-21-2014, 05:49 PM
Turtlehead's Avatar
Sometimes, although rarely, the brake booster fails thus taking away the forgiveness of pushing on the brake too hard. I would be checking that out if everything else is checking out OK.
Old 10-21-2014, 07:44 PM
lovely4's Avatar
Ok im going to check it out once again
pair8hd
12-05-2023 04:40 PM
M-train
03-08-2014 08:40 AM
Fat Ryan
06-23-2009 01:26 PM
HelpMe
06-05-2009 08:45 PM
bristow
07-24-2007 06:48 PM
Quick Reply: 1993 honda civic front brakes locking up
