1994 honda accord sputtering
i have a 1994 honda accord 5 speed and every time i stop at a red light or just have it idling it feels like its going to cut out i changed the plugs and wires could be be throttle positioning sensor or o2 sensor or any other ideas?
First, welcome to HAF.
Next, what do you know about the car? Meaning, are all of the tune up items up to date. I see you replaced the plugs and wires but what about the dist cap and rotor?
When you replaced the wires and plugs, was there oil on the end of the wires?
Is the CEL light on? It only takes a paperclip to check for any stored codes on these.
Next on my list, a good cleaning of the Idle Air Control Valve (IACV) and the throttle body (TB) only cost the time, a few rags, an old tooth brush and a can or two of carb cleaner.
After the cleaning, there is an Idle Relearn procedure you should follow.
Lets start with those and go from here
zomburs
07-07-2011 12:03 PM
xtremaggose
09-03-2009 09:57 AM
