1995 Accord Engine Shaking After Cooling Fans Turn On.
RE: 1995 Accord Engine Shaking After Cooling Fans Turn On.
Hi Fredi..
I'm thinking that your fuelpump is not delivering sufficent fuel to the fuel injector system.
I would start by checking that 1st...
Usually the 2nd fan is only engerized when the A/C is on. Compressor engagement usually increases the idle speed. Could be that: the A/C system is not functioning properly in conjunction with the fuel system.
RE: 1995 Accord Engine Shaking After Cooling Fans Turn On. A/C Overcharged???
I recently had my A/C system recharged at a shop. That's when all these strange symptoms started. I released A LOT of pressure from the system, but left just enough for the A/C to keep functioning. Now the car is now running fine when the A/C is on. The idle is actually consistent now. Before, there would be a single "bang" coming through the High Pressure A/C line before the cooling fans turned on, and then the idle would drop immediately. I'm thinking the system was overcharged. Thanks
POS-Accord92
01-05-2012 11:14 PM
