Sponsored by:
Sponsored by:
engine noise after timing belt replaced
Old 02-19-2012, 05:20 PM
mrenee's Avatar
Default engine noise after timing belt replaced
hello. I just got my timing belt/water pumped replaced on my 2005 accord ex v6. I have noticed that there is a loud squeaking/squealing noise now coming from the timing belt area. It is constant at idle and while driving. Any ideas to what this could be? Should I be driving it?
Thanks!
Old 02-19-2012, 06:02 PM
It could be the timing belt idler, or timing belt auto-tensioner and/or adjuster. If this was done by someone else, I would take it back. I wouldn't recommend driving it too much for now.
Old 02-19-2012, 06:36 PM
EXV6NIGHTHAWK's Avatar
I would take it back, and tell them to try again, or refund the labor charge so you can have someone else do the job. Who did this job? Dealership? Did they use OEM parts? I read something about a TSB on this issue, but I can't find it right now. Something about the water pump body being machined wrong, and causing the pulley to mount at an angle. The TSB involved adding a shim plate between the water pump and pulley.
Old 02-19-2012, 06:58 PM
Lovemy97HondaAccord
03-05-2014 06:04 PM
Accord01gt
01-08-2012 07:40 PM
BrotherAli
12-22-2011 07:18 AM
twinster2
07-06-2009 09:28 AM
Tony1M
04-01-2007 05:42 PM
Quick Reply: engine noise after timing belt replaced
