1996 Accord Rear Wheel Noise
Old 12-23-2009, 08:50 AM
accordwagoneer's Avatar
Default 1996 Accord Rear Wheel Noise
My wagon has started making a thumb-thumb noise in the rear, in time with wheel speed, not engine rpm. This started after a panic-stop in traffic, not from a pot-hole. I suspect a wheel bearing. Any suggestions?
Old 12-23-2009, 09:03 AM
Swap tires around to see if it moves to a new corner. That will check (or rule out) damaged bands in the tire.
Steer around corners in both directions. Bad wheel bearings will often increase or decrease as you steer. (OFTEN, but not always.)
Then lift the corner & spin the wheel. Check for dragging brakes. To actually check for wheel bearings, you might have to remove the caliper in order to spin the hub without any interference from the brakes.
Old 12-23-2009, 09:24 AM
Many thanks, will check once the !*@!^$%@((%)_) snow goes away here in N Va.!
Old 12-23-2009, 11:16 AM
poolman's Avatar
Since you said it started after a panic stop it sounds more like you "flat spotted" the rear tires and that would give you the thump-thump noise. There are a few places that can shave the tires to make them round again, but that will depend on how much tread is let and how bad they are flat spotted.
I live in N.Va also, we got close to 20" in Chantilly
Old 12-23-2009, 02:20 PM
Actually, there was no skidding when I hit the brakes (due to the excellent anti-lock) and the noise comes and goes, its not consistently there. I get a similiar noise when I rock the car body back and forth on its springs. When the plow stops refilling my driveway for me, I'll jack it up and see if the wheels make any sounds or are loose in any way. Thanks for your response.
dougs honda
04-25-2010 07:55 PM
zoneout
08-24-2009 06:30 PM
joe_smith
04-13-2009 08:30 AM
shadowrider
03-04-2009 11:06 AM
bogeymiang
12-11-2008 04:55 PM
Quick Reply: 1996 Accord Rear Wheel Noise
