1999 HonDa Accord Timing Belt
Hi My name is Ed and Im new on this forum.I have a 1999 honda accord,V6 V-tech.I'm thinking about installing a new timing belt .I would like to know how hard to change timing belt on 99 accord.Is there a special tool I might need ?Do I have to lift the engine to get some room?is there a web site to showing how to do it . .Your response would be great appreciate . .Thank you in advance!!
RE: 1999 HonDa Accord Timing Belt
Hi Guy...
Welcome to the forums, we thank you for joining up..
While your in there changeing that timeing belt dont forget to also change the balance shaft belt at the same time.
You will need a floor jack and a box of good tools and also a large screwdriver or large punch and a breaker bar and socket. Dont forget how you took them off cause you got to put them back on the same way...
Good Luck & Bust A Knuckle For Us All....just kiddin of course [sm=americanasmiley.gif]
dude, aloha, was in maui a few months back, wow is all i can say, great driving roads on the north side!!!
buy yourself a manual before you do it, unless your a pretty skilled mechanic the job is pretty involved and you have to watch your timing marks..
get the haynes repair manual, gives you step by step info
yo WHEELBROKER ,,,v6 does not have a balancer belt to replace ,, i would however advice to replace the Hydraulic tensioner ............i would strongly as well advice to get a factory helms manual if u plan on doing the job urself..,,,,,,If u are not mechanically inclined take it to a shop..
shafner30
03-20-2012 05:54 AM
