Sponsored by:
Sponsored by:
2000 Accord EX V6 Multiple Cylinder Misfire
Old 04-28-2016, 05:43 PM
I had misfire codes on my 2000 accord v6 found a bad coil but when I replaced it, I get a spark so I believe its a bad wire
Old 04-28-2016, 05:52 PM
Default Mulitble Misfire codes
I have a 2000 Accord V6 that has multiple misfire codes I cleaned manifold, intake changed all gaskets, cleaned egr as well new plugs, in the end I did a coil test when I have one that stays the same I bought a new coil plug and it still does the same but you can see the spark I believe I have a bad harness wire. those are 483.00 at dealer.
Old 04-28-2016, 05:56 PM
after all that work the car runs 100% better but you can still fill a little uneasiness and also I had the codes cleared but the light didn't go off and codes remained the same
tferstl
12-16-2014 04:23 AM
Florida_Frank
02-16-2014 07:28 AM
Stimn11
12-15-2012 03:59 PM
landlover
03-11-2008 07:02 PM
Quick Reply: 2000 Accord EX V6 Multiple Cylinder Misfire
