Sponsored by:
Sponsored by:
RPM at highway speeds
Old 02-03-2011, 10:36 AM
wunderbra's Avatar
Default RPM at highway speeds
Starting a new thread here about torque converter lockup. Dealer says he cannot verify the converter lockup on my obd1 accord. I recall on my other ones, it would turn 2700 rpms at 70 mph with the TC fully locked up. What are your numbers?
Old 02-03-2011, 11:21 AM
My 95 was a MT, so I don't know how they will compare. 2700 was about the rpm on my car at 70mph.
If you can find a used car lot selling 94-97 EX, you can ask to take it for a test drive and see. Not many wagons out there, but the sedan should be similar.
Old 02-03-2011, 05:31 PM
I've got a 95 EX 4 cyl auto-once it locks up at 65 mph I'm at 2250 rpm's....I changed the fulid last weekend and yes before that I was running closer to 2500 rpms at 65MPH. I'm sure with a few more miles on the new fluid it will go back up..so what are you running, you say the "others" were 2700rpms. On a level road holding gas steady, or cruise on, do you ever see the tach drop ~200-250 rpms?
Anyway, what has been done. Change fluid, clean soleniods, check throttle control cable.
Old 02-03-2011, 09:25 PM
colorado_accord's Avatar
My 91 and 92 both sit at 3k right 75 mph
Old 02-03-2011, 11:00 PM
wunderbra's Avatar
Solenoids checked, cable adjusted. One fluid change so far. Still no change. I did see a drop of 2-250 before, not anymore, so I guess I am not getting lockup, or at least partial lockup.
Old 02-03-2011, 11:26 PM
Not sure why you are not getting lockup.
There are some TCU codes that do not flash the D4 light.
If this is your 97: Have your error codes scanned at a parts store. Most do this as a free service. The connector is behind the ash tray.
If this is the 94, read how to get CEL codes in the DIY section.
Actually, you can do the DIY section procedure on both the 94 and the 97.
Just let us know which car your are dealing with and the code(s) you get.
Old 02-04-2011, 12:40 PM
07_Accord_SE's Avatar
I just got 73 at 2350 rpm.
Old 02-04-2011, 06:34 PM
wunderbra's Avatar
Sorry, should have said which car, It is a 95. I have updated my signature. There are no codes.
Old 02-05-2011, 12:04 PM
Dannyboi40's Avatar
I'm runnin 3k rpm at 75... about 3800rpm at 85mph...90 accord lx... seems high to me.. and that's in an auto trans... in 4th gear...
Old 02-06-2011, 07:05 PM
barticus520's Avatar
I dono if the engines run different but my 05 v6 runs at 2000-2100rpms at 70
Quick Reply: RPM at highway speeds
