2000 Honda Accord Starter help (2.3L 4-cyl auto)
Old 04-29-2013, 04:03 PM
benny148's Avatar
Default 2000 Honda Accord Starter help (2.3L 4-cyl auto)
I'm trying to remove/replace the starter in my 2000 Accord, but I'm having trouble getting to the bolt in the back side of the starter. I can't fit any socket/wrench to get a good grip on the bolt. I'm not sure what I can remove to get some more room.
I'm pretty new at DIY so any tips would be greatly appreciated.
Thx
Old 04-29-2013, 06:37 PM
Have you removed starter wires and coolant line? Disconnect battery negative terminal before removing any wires.
Autozone has a pretty good guide but no help w/ difficult rear bolt. You may need a "wobbly" extension to allow a bit more alignment flexibility. I've found wobbly extentions to be a great help.
Old 04-30-2013, 02:21 PM
benny148's Avatar
Thanks, the "wobbly" extension did the trick. Once I was able to get the bolt spinning, I used a ratchet wrench to get it out. After that it was smooth sailing. Pretty quick job overall, that hardest part by far was maneuvering to get that back bolt loose. Appreciate the help.
Old 04-30-2013, 06:13 PM
Thanks for followup.
I am not that familiar w/ the 98-2001 series Accords and was unsure about starter, but the AZ photos showed it to be similar to 94-97 Accords, hence my advice.
BSims66173
04-14-2013 06:11 PM
ganarul
06-15-2011 04:48 PM
Senior Taco
10-31-2009 11:11 AM
mrmatrix
08-12-2006 05:39 PM
Quick Reply: 2000 Honda Accord Starter help (2.3L 4-cyl auto)
