Do Accura RSX rims fit Accord2000 V6 ?
Old 02-20-2011, 12:53 PM
cadreck's Avatar
Default Do Accura RSX rims fit Accord2000 V6 ?
Anyone knows if Acura RSX rims would fit Honda Accord 2000 V6 in terms of clearing for calipers, bolt pattern is the same 5x114.3mm.
Thanks
Old 02-20-2011, 04:37 PM
Brake clearance should be the same as long as it's the same nominal size. RSX rims 15" or 16"? Or maybe 14" then they won't fit.
RSX is lighter, so 16" Accord rims might be wider than 16" RSX rims.
Got any more information about the specific rims?
Old 02-20-2011, 09:18 PM
cadreck's Avatar
Jim,
My Honda Acccord2000 EX oem rims are 15"x6.5", hole pattern 5x114.3mm (4.5"), I have winter tires on them now and need extra set for summer tires.
Someone is selling Acura RSX 16" used rims, I don't know the width but hole pattern is the same. I'm worried if caliper clearance is sufficient.
Do you think it would not be safe to use them on Honda, since Acura is lighter car?
Thanks
Old 02-20-2011, 10:18 PM
Supernaut's Avatar
The wheels will fit quite nicely. The stock tire size for the RSX is 205/55-16 which is slightly smaller in overall diameter to a 205/65/15. I would recommend going with the 205/60-16 used on the 2003 and newer v6 accords.
The width is the same on both at 6.5" as well as the bolt pattern at 5-4.5
Old 02-21-2011, 07:31 AM
You'll be fine for caliper clearance.
Like Supernaut says, your TIRE size for the Accord will be different than TSX tires, but I wouldn't worry about the strength of the rims.
Old 02-21-2011, 05:51 PM
cadreck's Avatar
As an alternative I'm looking at 17" TSX rims and 215/50R17 tires, would it be a better choice then RSX 16" as a summer replacement of my OEM 15" Accord rims?
The width on 17" is larger 7", would they still fit?
Thanks
Old 02-21-2011, 09:52 PM
Supernaut's Avatar
They most definitely should fit. The overall diameter of the 215/50r-17 may be slightly larger than the stock size for the accord...but a negligible amount at best.
Should have a very nice look overall!
Old 02-22-2011, 06:42 AM
Stock wheels for 2000 Accord coupe EX-V6 are 16 x 6.5. You'll be fine with either set of wheels. They'll be visually different, maybe you'll like the looks of the 17" better?
KevinFelt
12-06-2013 01:14 PM
Honda_Dude
06-18-2011 04:58 PM
mcknigs
10-07-2010 08:32 PM
stefanb21487
06-02-2007 03:50 PM
Peperoni Nose
10-27-2006 04:24 PM
Quick Reply: Do Accura RSX rims fit Accord2000 V6 ?
