2015 Accord EX dimming mirror connector pinout
A friend of mine broke the wires connecting the rear view mirror while trying to hang his disability tag. Probably a common event. I offered to repair it and have removed the pins from the connector. I need the wire colors, function and pin number. I believe it uses pins 5, 6 & 7 and the functions are +12, Gnd and Reverse. I don't know what order or color. Thanks for any help you can provide in helping this old guy to get on his way. The dealer was quoting $500 plus for the repair.
I don't have a 2015 accord manual, so let me see if the wiring matches older accords.
How many wires were in the harness to the mirror? How many pins in the connector? Also the pin arrangement (like 1 row with 7 pins).
You should measure the voltage/ground on each wire to determine if they are functioning properly.
The connector is a 7 pin with all 3 pins at one end. I do not have the car in my possession at this time so I can not give you the 3 wire colors. I have a volt meter so I will be able to get everything except the order that they go in the connector. The wires broke off at the pins so there was no insulation on there to match. If some one would look at their mirror and connector and the wire colors and tell me how they are arranged in the connector I would be good to go. Thanks again.
Mr. Sandog
01-09-2011 01:15 PM
