Sponsored by:
Sponsored by:
2001 LX front passanger Power Lock issue
Old 02-09-2016, 02:01 PM
ju5tin95's Avatar
Default 2001 LX front passanger Power Lock issue
Hi Guys im new to HAF,
I have a 01' LX 4 door and when someone manually pulls the front passenger door lock open , it doesnt lock or unlock from the central locking on the driver side. I see it trying to move sometimes, but when i was checking the fuse for it, 10 min later it was fine and working again untill today, my co-worker pulled on the lock **** and started again. Should I open it up and see the actuator? it seems to still work and I think that when they pull on it manually it just gets pulled out of something.... but when I lock it from the outside with my key on the passenger side all the locks open and close all together.
Old 02-10-2016, 11:43 AM
Dr. Drivability's Avatar
When you use the key on the passenger door, there is no electrical actuation happening, so the lock works. The rest of the doors locking and unlocking is a feature of the lock cylinder circuit. I would say the actuator for the suspect lock is either failing or has a bad connection.
Old 02-11-2016, 11:19 AM
ju5tin95's Avatar
awesome thanks! should I get a new one from Autozone for about 38 they says its a dorman brand but has a lifetime warranty
Old 02-11-2016, 11:44 AM
I always lean toward OEM parts, unless the they are cost prohibitive. Have you checked Honda pricing yet?
sanchdaniel
02-05-2011 06:59 PM
tru3_k177
01-11-2008 01:18 PM
Calevra18
09-21-2007 11:46 AM
RoKnAzn
05-16-2007 01:46 PM
RoXeTTeMaN
08-05-2006 03:22 PM
Quick Reply: 2001 LX front passanger Power Lock issue
