Sponsored by:
Sponsored by:
how to replace ignition switch on 97 accord
Old 04-11-2011, 02:12 PM
westcoasthonda's Avatar
Default how to replace ignition switch on 97 accord
is there a write up? the person i got the car from said that was the problem
Old 04-11-2011, 04:07 PM
Did you download the 94 shop manual?
Old 04-11-2011, 06:52 PM
ya, its on there?
Old 04-11-2011, 07:00 PM
I think ignition switch is under the electrical section.
Old 04-11-2011, 07:12 PM
I've done this on 94 EX. It's an easy job.
1) Remove upper and lower covers. I think 4, Torx-head screws (not sure of size). Covers are held together w/ some snaps, so you have to force apart after pulling screws.
2) Disconnect electrical connector to switch.
3) Remove 2 security bolts (round heads) holding switch in place. Use a sharp awl or cold-chisel to hit the bolt edge and turn the bolt head CCW. One blow each was all mine req'd. Once loose, you can turn w/ fingers.
4) Pull switch.
Reverse for installation.
Old 04-12-2011, 12:03 AM
alright thnx
Matthew Kniss
06-30-2014 06:00 PM
DA KID RYU
08-05-2009 05:38 AM
Redcap
05-07-2008 05:29 PM
Mikebike125
01-18-2008 07:07 PM
illfaver
08-30-2007 03:02 PM
Quick Reply: how to replace ignition switch on 97 accord
