2002 accord cylinder misfire - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
LinkBack Thread Tools Search this Thread
Old 04-07-2011, 06:54 PM
Question 2002 accord cylinder misfire
Hi all,
I was experiencing jerks when driving on highway. Now there is jerk when the car is in idle. Couple of days ago the check engine light lit up. I went to local auto store to get the code. It had 5 defects. All of them point toward misfiring engine. Basically 3 of my 4 cylinder are misfiring. Anyone suggestions??
P.S. I am new to DIY. I changed the brake pads recently with the help of DIY in this forum.
edit approx. 120000 in the car
Old 04-07-2011, 07:01 PM
Take a look in the owner's manual to see when you should change the spark plugs. When were the spark plugs last changed?
Old 04-07-2011, 07:07 PM
It has been a long time since I changed the spark plugs. I will change it and see if it helps. Thanks
Old 04-07-2011, 07:35 PM
Your accord uses platinum plugs, so they should last a long time. I can't remember the maintenance interval, but your owner's manual will have that info. I think that they last 90K.
Always use NGK or Denso plugs recommended in the owners manual. NGK PZFR5F-11 are the ones that you want.
Bad gas can cause some problems.
Also, post all of the error codes that you got. The start with the letter P and have 4 numbers, like p1234.
Old 04-08-2011, 12:40 AM
I read the code in a local store. I don't remember the code numbers. The descriptions were cylinder 1 misfire, same with 2 and 3, fourth one was something like random misfire however I don't remember the last one.
Also I bought the spark plugs. It is platinum plugs. I will check if they are NGK PZFR5T-11. The store employee recommended the plugs and I got it.
PS bought the car from a friend, not sure when he last changed the spark plugs
Old 04-08-2011, 03:41 AM
If you are ok with spending the money on new spark plugs, then try it. I hate advising people to throw money at their car, but this is a maintenance item.
Old 04-08-2011, 11:14 AM
I'd say bad gas too. no reason for you to have 3 of 4 cylinders misfire.... put some new gas in it and run some fuel injector cleaner through it. change spark plugs if you want they're cheap enough. make sure you gap the plugs. if its running better after the injector cleaner just go through another tank and have your shop reset the codes so your engine light goes off. this recently happened to my fiances car because it was sitting with the same gas for a few months runs great now.
Old 04-08-2011, 07:27 PM
Will change the sparks and put in some fuel injector over the weekend. Will update how it works out. Thanks
Old 04-11-2011, 10:14 PM
Changes the spark plugs and the car seems to be running good. Thanks forball the help. I did put in some fuel cleaner and changed the filter as well. However the check engine light is still on.
Reply
Thread Thread Starter Forum Replies Last Post
2000 Accord EX V6 Multiple Cylinder Misfire Resatimm General Tech Help 12 04-28-2016 06:56 PM
02' Accord EX V6 Cylinder Misfire with Solution Devon7234 General Tech Help 3 05-25-2014 10:22 AM
2000 Honda Accord SE Cylinder Misfire Code P1399 Stimn11 General Tech Help 19 12-15-2012 04:59 PM
98 Accord Dies after startup/Cylinder misfire code bobrae2011 General Tech Help 7 08-05-2012 10:35 AM
98 Accord LX 4 Cyl - Multiple Cylinder Misfire - Catalyst System Efficiency Below Thr anandram General Tech Help 6 01-08-2011 02:02 PM
Tags
05, 2002, 24l, 4cylinder, accord, cylinder, drive, engine, fire, honda, misfire, misfiring, miss, missfire, plugs, safe, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
