Sponsored by:
Sponsored by:
2002 Accord Tranny
Old 07-01-2015, 09:49 AM
dtillman15's Avatar
Default 2002 Accord Tranny
I have a 2002 Accord Ex V6 3.0 Coupe. I need to know if I can take a transmission out of that and put it into a 2000 V6 coupe and not have any problems. Thanks guys.
Old 07-01-2015, 10:07 AM
A quick check of car-part.com indicates no differentiation of parts crossover by body (4dr or coupe), only by year. I found nothing in a quick look at shop manual to suggest coupe is different.
You can find a used trans by using car-part.com and your zip code to find a local salvage yard w/ a trans.
This generation AT's were somewhat more problematic than other gens.
Old 07-01-2015, 10:27 AM
dtillman15's Avatar
Okay so I should be fine to just swap transmissions? Thanks. I appreciate the help.
Old 07-01-2015, 11:11 AM
shipo's Avatar
That's not exactly what he was suggesting; you should confirm there is a good interchange between the 2000 and the 2002 model years. That chances are very good, but by no means certain, the interchange will work.
Edit:
Given how potentially problematic transmissions are for the Gen 6 V6 cars, there is no way I would buy a used transmission with an unknown pedigree; better by far to spend a few extra dollars for a remanufactured transmission with all of the latest upgrades.
Old 07-01-2015, 11:30 AM
Turtlehead's Avatar
The best way to verify a transmission swap is to confirm the VIN part number search for both vehicles. BUT, I have done dozens of transmissions on your generation with the V6 and have not seen any difference. You can even look at pulling one out of an Acura. The only thing that you need to be sure of is the mounting bracket, but the bell housing should bolt in fine, SO make sure the mounting bracket to the sub-frame is correct... You should not have any issues with the above being said.
Old 07-01-2015, 12:29 PM
dtillman15's Avatar
My car is essentially totaled. It's the 02. His is a 2000. We are both V6 vtec 3.0. But you're saying that with that situation, I shouldn't have any problems?
Old 07-01-2015, 12:33 PM
shipo's Avatar
Which Acuras? Correct me if I'm wrong, but it is my understanding the contemporary Acuras (the TL and the CL) to the Gen 6 Accords all had 5-Speed automatics. Are you suggesting the Acura 5-Speed automatic will bolt into a Gen 6 V6 Accord?
NeyVtec
04-11-2015 12:57 AM
Mr500CM
06-06-2014 07:42 AM
bigdawg74
02-20-2010 11:20 AM
92accord808
09-30-2009 03:36 PM
jtech
01-19-2009 11:26 AM
Quick Reply: 2002 Accord Tranny
