2004 Honda accord fuel system. Not running.
Hey guys, recently a buddy of mine had a fuel system service done on his car. It was running fine for about two days. The third day I went to go on a short drive and the car hit 20mph and started sputtering and wouldn't let me go past 20mph and car was running rough. Now when I go to start it it won't completely turn on. It turns over but hesitates to fire each cylinder. Any help would be greatly appreciated. Here's a video to help
Don't think one is related to the other, it could be but most times things just seem to be related.
First, check for stored/pending codes.
Are the plugs up to date?
When the key is first turned to "on"/pos-II what lights on the dash come on and go off - or not go off - does the fuel pump prime for a few seconds while this is going on.
Noticed "jumper" cables in the video - is there a battery/charging issue?
Suggest checking fuel pressure. Very low fuel pressure might cause symptoms.
A good test is a blast of starter fluid or throttle body cleaner and see if it starts better and runs briefly. If yes, the fuel system service may have created a problem; leak, blocked injector/s, wiring, etc.
90accord90
01-25-2010 03:28 PM
