2005 Accord Hybrid Check Engine Light Code
My wife has an '05 Accord Hybrid. The check engine light is on. We did the paperclip thing and got a flash code of 69 from the MIL light and a code of 78 from the MIL light.
So far I've had no luck in finding what these codes mean. Can anyone help?
Thanks.
Thanks.
RE: 2005 Accord Hybrid Check Engine Light Code
yeah, that is an IMA code but it can either be an A/T pressure control solenoid C problem or the IMA battery is loosing it's efficiency.
however depending on the code it there are several fixes - p15A5 - we update the IMA software.
p0A7F- also fixed by updating the IMA software.
certain VIN numbers also get a PGM FI software update.
if it recodes you'll need to replace whatever is fault. the IMA warranty is: (years/mileagex1000)
the software updates are 3/36
Integrated Motor Assist System (IMA)
Battery Assembly (including all internal
8/80
components)
DC-DC Converter
8/80
Motor Control Module
8/80
Motor Power Inverter Module
8/80
Motor Rotor
8/80
Motor Stator
8/80
Busbar 3/36 3/50
Bypass Contactor 3/36
Bypass Resistor 3/36
High Voltage Contactor 3/36
Battery Current Sensor 3/36
Motor Rotor Position Sensor 3/36
Motor Current Sensor 3/36
Motor Power Cable 3/36
High Voltage Motor Power Inverter 3/36
Module Cable
Intelligent Power Unit Air Duct and Fan 3/36
Power Control Unit Air Duct 3/36
Motor Power Inverter Module Fan 3/36
Control Relaythe software updates are 3/36
78gaw
01-20-2010 09:45 AM
ddold@gkschools.org
01-29-2008 03:35 PM
