2005 EX - A/C on, driver's side hot air, passenger's side cold air
2005 I4 EX.
When I turn the heat control dial, I can hear something move inside (which tells me everything is supposedly working fine )
I turn the A/C on - I get super cold air from both passenger's vents (side and center), but normal/outside temp. air from both driver's vents.
While A/C is on I turn the temp. dial to heat - all four vents blow hot air.
Back to cold - same situation as above (passenger - cold; driver - normal air).
This happens in both A/C and MAX A/C.
Any ideas what could it be and how to tackle it?
Thanks.
Thanks.
Edit: OK, I read the other post. Weird...the design of the evaporator can cause this "divide". I'll check refrigerant. Thanks!
Sapowell84
07-16-2013 03:18 PM
bigbadbuff
04-17-2012 12:56 PM
19accord92
04-10-2006 03:52 PM
