2007 Emissions Dash Light
The light came on today and seems to be staying on. I did read the manual and it is not the gas cap. I plan to wait a few days to see if it just sensed something irregular or intermittent and maybe it will go out. If it doesn't go out my question is how do I troubleshoot which component is bad in the emissions? Do I need to spend big $ at a dealer for them to hook up to a computer and diagnose?
Thanks,
Scott
Thanks,
Scott
Go figure...the light went out after staying on for one full day. I did replace the battery the day before the emissions light came on. Could that have triggered it to come on possibly? Hopefully just a fluke. I'll know what to do next time if it comes on and stays...off to the parts store for a free code scan. Thanks.
My emissions light came on Tuesday afternoon. I stopped by Advance Auto Parts this morning (Thank you PAHonda). The computer said the code is P1285: Engine Coolant Temperature Sensor. What are my options? What could be the problem? Is this going to be an expensive fix?
Doesn't sound bad. I do not own a proper manual for an '05 (might try the Common DIY Threads or automanualsource ~$27 online) to bet sure of the testing procedures,,,,,before just replacing the switch.
Redbull, do you have anything on this?
For the newer Hondas, P1285 - Accelerator Pedal Position Sensor 3 Circuit.
Possible cause: wiring, APP sensor, or ECM/PCM
