Sponsored by:
Sponsored by:
2008 Accord V6 automatic, jerky throttle response
Old 01-09-2011, 08:00 PM
excamryguy's Avatar
Default 2008 Accord V6 automatic, jerky throttle response
My '08 Accord V6 automatic has a very annoying jerkiness when accelerating at lower rpm's (1500-2000 most noticeably). It's worse with a cold engine and under a bit of a load like up a slight grade. I've noticed it since the car was new when it was fairly subtle. However, it's gotten progressively worse and less subtle. My dealer's service manager says he's not aware of this being a problem and checked with Honda for service bulletins but there are none. Although he says my car is performing like they all do I find this hard to believe. I can't imagine any manufacturer, least of all Honda, finding my car's performance acceptable. Any suggestions as the dealer thinks I don't have a problem?
Old 01-09-2011, 10:17 PM
ßlåçk§mókè's Avatar
Junior Member/Canadian Connection
It sounds like your not letting the engine warm up to the point that everything is lubed with oil... try letting the car warm up and see if that helps...
Old 01-09-2011, 11:24 PM
No suggestions about this in this New Members forum, but post that ??? in the Genl Tech forum and you will get answers..
Welcome to the HAF...and watch where you post your questions.
Old 01-10-2011, 07:05 AM
g22cd5's Avatar
Supper Moderator
warming it up has nothing t do with it.
moved this in the right area
Old 01-10-2011, 07:26 PM
A reach and an idea.(EDIT: or the other way around)- Have you tried another dealer, of course the new dealer may see the records from the one you are currently going to.
Honda: low power during acceleration. Vehicles may experience an intermittent lack of power due to interference or noise on the knock sensor signal circuit.....TSB# SB-07-057
Doesn't say anything about "cold" but pretty close, also says intermittent which may be different than what you have?
Old 01-10-2011, 08:12 PM
excamryguy's Avatar
Thanks for your suggestions. I've been to two dealers neither of whom has a clue. One said he found that the Odyssey had something similar that Honda put out a service bulletin on, but nothing on the Accord. I've made a note of your idea which I'll present the next time I go for service. I bought a Honda to avoid having to become a technician, but I guess it didn't work out!
Old 01-10-2011, 09:01 PM
Honda TSB 07-057 is applicable to the Accord with the L4 engine.
Mad Professor
09-14-2014 07:14 PM
RobinsonRicer
01-25-2013 11:17 AM
RobinsonRicer
10-09-2012 03:53 PM
Morgan
03-03-2007 03:15 PM
nwurts
06-27-2005 03:03 PM
Quick Reply: 2008 Accord V6 automatic, jerky throttle response
