Transmission Fluid help
I have a 2005 Honda Accord LX SE Coupe, Automatic.
I went to Honda and they have a ATF DW-1 Genuine oil for $7.97 (1 quart). They said I need 3 quarts. Also they said I need 2 crushers, top and bottom which is about $2 each.
Should I buy this or buy Generic from another store?
Also, there is a oil change shop that will change it for me for $20 if I bring my own parts.
Any suggestions?
Any suggestions?
Get the Honda ATF DW-1. I used this on my 2009 Accord and my nephew's 1995 Accord. Both cars shifted very smoothly afterward, mixed with the Honda Z-1 that still left in there.
You just need the one crush washer for the drain plug. For the AT transmission for the 4 cylinder, you fill the fluid through the oil filler tube where the dipstick is.
$20 is very reasonable for the labor.
So 3 quarts is perfect?
I bought this car at 40K and now I am at 86,650. This will be the first time I am changing transmission fluid. Last year, I checked and the color was not black but not is is black. If I change it this week, will I be ok with no damage? I am not even sure when the last owner changed the oil.
What do you mean? What is one drain? I thought you drain all oil?
