Sponsored by:
Sponsored by:
6th gen intermittent A/C
Old 08-31-2015, 08:32 PM
dimension12's Avatar
Default 6th gen intermittent A/C
98 lx with 4 cyl. AT w/manual hvac control. All lights work as they should. During high humidity days, there is no signal to trigger the a/c relay. When the humidity drops the system will work intermittently. I do not have any codes from the hvac control. I have unplugged and plugged the evaporator thermostat and after a delay the system works for awhile.
I have removed and inspected the circuit board. Found no obvious signs of a problem. Used an Ohm meter to test between the terminals for the jumper wire and had continuity. I am second guessing myself that this is the proper way to check if I need the jumper wire.
I am thinking I should just do the jumper wire to eliminate the board. All the posts I have read on the subject state the hvac lights go out when the board is bad. As I said in the beginning, my lights work.
Evap tstat maybe?
Old 09-02-2015, 11:34 AM
Does anybody have any ideas? The misses is tired of driving without air conditioning.
Old 09-02-2015, 03:09 PM
Suggest checking yel/grn wire at AC pressure switch connector when AC is commanded On. It should show a ground connection from AC control board. If not the AC control board has a fault.
If a ground is present on Yel/Grn, disconnect AC pressure switch and check switch side contacts for short (switch closed zero resistance). If open (infinite resistance), then either your charge is low or AC pressure switch is faulty.
Old 09-02-2015, 03:36 PM
Thanks Texas. I was just looking at a wiring diagram and decided to test that tonight.
Old 09-02-2015, 09:10 PM
no ground at that wire and the switch is good. I jumped the b/r wire and the system operates. Now I need to trace it back.
Old 09-03-2015, 08:23 AM
The ground is supplied by AC control board, so either a fault in the wiring or connector, or a faulty control board.
Check the G401 (ground for the AC/Heater Control Board is good.
Old 09-03-2015, 03:30 PM
Texas, can you tell me where the G401 is? Also where can I find the heater board schematic?
Old 09-04-2015, 09:34 AM
G401 is on the driver's kick panel area behind kick panel underneath the under-dash fuse box.
The Honda shop manual shows only an abbreviated diagram and no pics of circuit board.
You may be able to find a free shop manual online, or purchase from automanualsource.com for $22. I think someone found an free online manual yesterday.
Elk Hunter
10-02-2012 11:08 AM
coolcat
11-24-2008 08:39 AM
Ponyboy
06-01-2008 01:13 PM
finch13
04-15-2008 10:13 AM
bigdog1428
12-19-2006 09:07 AM
Quick Reply: 6th gen intermittent A/C
