Sponsored by:
Sponsored by:
87 accord lxi starter
Old 03-09-2005, 12:15 AM
daemonhat
Default 87 accord lxi starter
i just bought my first honda, an 87 accord lxi 2.0, and the starter went out today, i was able to remove one of the bolts, but cant for the life of me find the other one, prolly didnt help i was in a parking lot in the dark using a flashlight, lol, i found a diagram showing where it is, but it didnt really say how to get it out, i.e. (re)move hoses, wires, etc. just said to remove both bolts. there looked to be several hoses directly above the solenoid, dont know if i have to take those off or what. ahh, the joys of owning a front wheel drive foreign car, lol. any help would be greatly appreciated
Old 03-26-2006, 01:43 AM
Default RE: 87 accord lxi starter
there should be another bolt under the starter i have changed many honda starters look harder or try and feel
Old 03-26-2006, 09:58 AM
mbo1985's Avatar
it's not too hard all. you'll have to get it from under the car though. Reach up from near the transmission and you should be able to see it. The wires come off easy too. One should just slide off since it uses a blade connector and the other is held on with a 10 or 8mm nut.
I had to change mine out once at my girlfriend's driveway at night, and knowing where everything was certainly helped. Don't kick yourself though, since it is tricky to find the bolt the first time. You may even need to move the splash shield out. And I think I remember the main radiator hose being attached to a bracket supported by the starter. Just be careful with the hose and it shouldn't give you any problems.
raydavid93
03-16-2013 09:23 AM
wknox
01-24-2011 09:09 AM
Rated///M
02-16-2006 02:50 AM
Sellmanb
12-27-2005 03:02 PM
86accordlxi
11-13-2005 04:09 AM
Quick Reply: 87 accord lxi starter
