90 Accord antifreeze pours out, now won't start?
My brother-in-law's POS Bonneville was in the shop so I let him drive my trusty 90 Accord DX, 160K miles for a few months.
Five minutes after he parks it in my driveway, steam is coming from the engine and my antifreeze is gone. He says it's just a hose, but I think the problem is more serious but can't figure out what.
Last week, I cranked it up to see what was going on. Started up just fine, no problem, I even backed it out of the driveway. I cut off the engine and checked the fluids. The radiator was bone dry, so I filled it up. Oil seemed fine. Not five minutes later, I try to start it up and it won't fire. Antifreeze is coming out in a steady stream from somewhere above the oil pan... couldn't see from exactly where. It's still cranking, but just not firing. Even when I spray Starting Fluid in the intake, it tries to fire but still sputters out.
Any idea what's wrong?
I would check for engine codes. Read the thread about How to get CEL codes in the DIY section.
If you have a timing light....I would try to use the timing light on each spark plug wire. You want to see if there is enough spark to flash the timing light.
Check the heater hose, part of it is runs under the distributor. If it is leaking there, coolant may have sprayed and gotten some into the distributor and spark plug wires.
Similar thing happened to my nephew's 95 Accord; it would start and run; but, ran very rough and had no power. After the hose was replaced, and things dried out, it was back to normal. Yous may have gotten more coolant into the distributor or onto the wires.
There is a weep hole on the rear side of the water pump, there is a possibility the water pump went bad and the timing belt could have jumped timing.
Also there is a coolant transfer tube across the back of the engine that goes into the waterpump housing.
txredrage
01-08-2014 10:52 AM
Kyle Hopfensperger
08-30-2013 08:45 PM
xang0
07-06-2009 03:22 PM
