90 accord brake light problem - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 01-25-2008, 12:51 AM
dbro
Default 90 accord brake light problem
I have a 90 honda accord with brake light problems. Here's how it goes:
When headlights are OFF:
-when I brake, the two front corner marker lights come on (as if somehow wired directly into
the brake lights)
-"brake lamp" dash light is lit
When the headlights are ON:
-brake lights stay on all the time, whether I'm braking or not
-dash lights dim when I actaully am pressing the brake pedal
anybody have any suggestions? cuz I can't very well go around with my brake lights on at night all the time...
Old 01-25-2008, 08:27 AM
Default RE: 90 accord brake light problem
Check for a bad ground at therear lampclusters.
Then check for an un-wanted connection between brake & taillight circuits at the rear lamp clusters. This can also be caused by bulbs being installed wrong.
The combination brake/tail lamp bulbs actually have 2 filaments, & they have 2 little contact nubs at thier base. They're only supposed to go in the socket one way, but they can be forced in backwards to cause this problem. Or... a single-filament bulb was installed where it should be a 2-filament bulb.
Or... one time I saw the 2 little contact nubs at the base of a bulb had been mashed so the contacts inside the bulb socket would touch both nubs together.
Reply
Thread Thread Starter Forum Replies Last Post
95 Accord Coupe: brake light and backing light on right side not working! WindPhoenix General Tech Help 9 08-10-2012 10:15 PM
My hand brake light stays on when hand brake is not engaged DannyJdm General Tech Help 4 03-28-2012 08:03 AM
Dash Light, brake light turns off when press brake pedal victorywhity General Tech Help 4 03-24-2011 09:37 PM
Three dash lights on simultaneously: Battery Light, Door Ajar Light, Brake Light wize_n General Tech Help 1 10-10-2008 06:49 AM
Brake light monitor for Hand Brake help? 98accord98 General Tech Help 9 09-08-2006 01:25 AM
Tags
1990, 90, accord, brake, brakes, break, dash, dim, honda, lamp, light, lights, problems, rear, repair
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
