Sponsored by:
Sponsored by:
97 Honda Accord V6, speedo and not tach not working
Old 12-09-2009, 08:20 PM
MoDawG
Default 97 Honda Accord V6, speedo and not tach not working
I picked up a 97 Exr v6 today with 136 km on it. The tach and speedo are not working. My friend told me it could be the ignition coil or something which is a common thing for these cars? Is he right in blaming the ignition coil or is it something else?
Old 12-10-2009, 07:00 AM
The tachometer signal comes from the coil in those first couple years of V-6 cars.
But... that doesn't explain the speedometer. I'd check for loose wiring connections behind the cluster, since that's about the only thing that speed & tach have in common.
Speedometer signal comes from the VSS which is on the transmission. Maybe(?) it's just a coincidence to get wiring problems on both those separate items?
RI Accord
04-28-2013 10:24 AM
cutlass327
06-29-2011 12:32 AM
Borico4life
05-30-2011 06:50 AM
Kimota
02-16-2011 10:30 AM
kevinabb
04-27-2010 10:45 AM
Quick Reply: 97 Honda Accord V6, speedo and not tach not working
