91 accord lx, door/trunk open warning lights - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 08-08-2010, 02:30 PM
Default 91 accord lx, door/trunk open warning lights
Have a 2 door LX, and all 3 dash lights indicate the doors/trunk are open - regardless if doors are open/closed.
Is there something unique to the circuitry that would cause this?? No way all 3 switches freaked out at exactly the same time.
Thanks
Old 08-08-2010, 08:25 PM
hondadude's Avatar
Have you tried jogging the 'test' button?
Old 08-09-2010, 05:32 PM
Quote:
I don't believe I'm familiar with the "test" button. What/where is that??
Old 08-09-2010, 06:18 PM
I'm not sure what hondadude meant either.
Do the courtesy lights in the doors and in the trunk turn on and off when the door/trunk is open and closed?
Old 08-09-2010, 08:32 PM
no...they stay on all the time as long as the car is running. Doors/trunk open/closed...makes no difference.
Old 08-09-2010, 09:09 PM
Whenever strange lighting issues pop up, I would start looking for a bad, loose, or corroded grounds. I would remove the ground bolt, use some sand paper to clean the connection and the bolt/washer, then tighten back down.
The spooner link I posted in the online manuals thread in the DIY section has a 93 shop manual that is for UK cars. It should give you a general idea of where the grounds are located. It may or may not be identical to the US accord. I would think that the ones in the cabin under the dash and in the trunk would be possible culprits.
It is possible that a wire is grounded somewhere near the gauge assembly that would cause this to happen too.
Reply
Thread Thread Starter Forum Replies Last Post
Door Lock when Trunk is Open Corvair General Tech Help 3 01-25-2015 08:31 PM
97 accord 4 door dash door open lights TexomaAccord General Tech Help 2 04-09-2014 10:53 AM
Driver door not recognized as open/closed. No courtesy light or dome light when open. cmel3 General Tech Help 4 05-31-2013 09:10 PM
ALL door open warning lights FLASH ON Greenbamboo General Tech Help 1 02-04-2013 10:03 PM
Door and Trunk Open Monitor on 2008 Accord EX-L 3.5L V6 Sedan Aceimager General Tech Help 2 03-27-2012 01:09 PM
Tags
90, 91, accord, ajar, dash, display, door, doors, honda, instrument, light, lights, mechanic, open, stay, trunk, warning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
