'91 steering pump removal?
Old 11-25-2009, 05:22 PM
Torino
Default '91 steering pump removal?
How do I get the steering pump out of the way to get to the alternator? Looks like the solid line on the top is in the way to remove the top bolt.
Old 11-25-2009, 08:56 PM
deserthonda's Avatar
remove the 2 10mm bolts that hold the p/s pressure hose in place, move hose out of the way,, keep the hole upward position or p/s fluid will come out,, once hose is out of the way remove the 2 remaining bolts that hole the pump in place, also remove the soft hose held in place by a clamp .keep the hose upward as well or p/s fluid will come out .
Piece of cake.. :-)
Old 11-26-2009, 02:45 AM
Torino
Thanks a ton. I was not sure I could remove those hoses.
Old 11-26-2009, 05:08 PM
Randy367's Avatar
I have a 93 Accord and yeah remove the PS pump, I changed my alternator without removing the pump and it was a pain in the butt. Today I pulled the pump off to change the seals and I wish I would have known it was this easy when I changed my alternator because it would have saved me a ton of time and a lot of headache. Yeah I just tied up my hose's to keep them up out of the way and to keep fluid from leaking out. Don't worry it's a piece of cake.
Accord1999
12-18-2012 09:41 PM
creator1322
12-06-2010 03:40 AM
kissbally78
01-18-2009 07:14 PM
abelh7
07-28-2006 04:01 PM
vdabis
05-11-2006 12:18 AM
Quick Reply: '91 steering pump removal?
