92 Accord LX Not Heat
Old 03-29-2006, 07:04 PM
eckhart's Avatar
Default 92 Accord LX Not Heat
Hi,
I just bought a 92 Accord LX and when I first drove it there was plenty of heat. Yesterday, I drove it for quite a while and noticed that the fan was blowing cold. The engine got up to temp but the heat did not come from the vents. I fiddled with the controls and nothing.
I'll be checking it out in more detail tonight, but does anyone have any suggestions?
Thanks!
Old 03-29-2006, 07:19 PM
sir_nasty's Avatar
Default RE: 92 Accord LX Not Heat
quick and easy, check your coolant levels... if it's not full your heater core won't get coolant and heat up... also, watch your gauges really closely to ensure your engine isn't overheating.... if your thermostat isn't opening up your engine will overheat and you won't get any warm air because you'll have no coolant flow to the heater core... If it starts to overheat SHUT THE CAR OFF!! A thermostat is about $5.00... an engine is about $3000.00 installed...
Old 03-29-2006, 09:43 PM
eckhart's Avatar
Thanks for the reply. I checked coolant and it is green and topped up. I checked the heat slider and it appears to have come disconnected under the dash as the level doesn't move the parts behind it. I know have to figure out why it came apart and how to repair.
skijour
08-15-2012 08:31 PM
Cessna172
11-05-2010 01:22 PM
BHoward711
04-12-2010 08:57 PM
longbowhunter
08-09-2007 10:31 PM
MasterFlex
08-08-2007 01:03 PM
Quick Reply: 92 Accord LX Not Heat
