Go Back   Honda Accord Forum - Honda Accord Enthusiast Forums > General > General Tech Help
Sign in using an external account
Register Forgot Password?
Search
Welcome to the Honda Accord Forum - Honda Accord Enthusiast Forums.
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Reply
LinkBack Thread Tools Search this Thread
Old 09-04-2011, 12:49 AM
Honda_Lady's Avatar
1992 Honda Accord
TheOnlyButterflyLady
Default 92 Accord shifting problems
Hello everyone. i am new here. sorry for my first post to be one asking for help. I searched through 10 pages of this section and didn't find any threads with similar problems. If i overlooked it please direct me that way.
i have a 92 Accord 2.2L EX with an automatic transmission. 2 weeks ago (August the 21st (Sunday)) the D4 light started flashing GREEN. I also had a major fluid loss as well as shifting problems. I put fluid in twice that day and it hasn't lost any fluid again since (i check it every day) and for the most part has shifted fine until today. i called my Honda friend and he said 2 things. 1) the transmission was gone 2) to pull the "back up" fuse to reset the codes and see if they came back on and was going to look up the codes for me when he went to work. the same week on Friday the light started flashing again. i pulled the codes that time and found a site that had a list of codes. now i don't know if it's all the same for all years and if it's not the same for all years if the ones i found are even the right ones. i had 2 codes. according to the list i found my 2 codes are the following: 7 -Shift Solenoid 'A' circuit open or shorted. 15 -Kick down switch circuit shorted. now i had to look up what a Kick Down switch did. i know where the shift solenoids are and what they do. at first i thought maybe they were shorting off each other. now i can only manually shift the car and it still flakes out sometimes going into second and third. putting it into D4 it wouldn't shift at all on it's own. i pulled the "back up" fuse again to reset it and now it shifts fine again. i really need to figure out what it is causing this. i think it was a year or so ago that i replaced the TCU because it was causing a no shifting problem. the GREEN light just stayed on no matter what gear i was in. i put a used TCU into the car and perhaps that unit now has a different problem from the last one or maybe it's the shift solenoids themselves?
PLEASE any assistance would be greatly appreciated. i can't afford a new car and i can't afford for this car to die completely. Thank you all so much in advance.
This ad is not displayed to registered members.
Register your free account today and become a member on Honda Accord Forum!
__________________
92 Accord 2.2L EX A/T
Old 09-04-2011, 08:41 AM
A "major fluid" loss that goes away without any work being done is VERY strange.
Then I would check/test/clean the solenoid(s) for proper operation and be sure to inspect the connector pins, be sure they are clean and making a good connection.
__________________
66 Chevelle...89 LX Auto...89 LXi 5 spd...95 EX Auto...07 Pilot...(soon to be sold-88 LXi Auto)
My child arrived just the other day, he came to the world in the usual way
Heaven is in the palm of my hand and it is waiting here for you, what I am I suppose to do with a childhood tragedy
Old 09-04-2011, 11:24 AM
Honda_Lady's Avatar
1992 Honda Accord
yea i know it's strange but hope it doesn't happen again. it lost enough to not touch the dip stick but didn't take much to bring it back up to the proper level. also when i lost fluid the second time there was no sign under the car of it having leaked out. so where did it go? i don't have a clue but i lifted the front end of the car up and crawled under as well as 2 guys from my church. (i did this in the church parking lot) the only fluid i saw was oil which i already knew about that leak.
ok i will do that. i was also wondering if perhaps it was the computer again because i can pull the back up fuse for a 10 seconds and the car shifts normally again. i am very confused by this. i would think if it was the solenoids themselves that pulling a fuse wouldn't temporarily fix it just like that. (i worked at Honda for a year, and graduated from the Automotive program here)
__________________
Old 09-04-2011, 11:47 AM
I'm hoping for the best too. Just know it very well could be the TCU.
Once the code is set, the tcu will go into "limp" mode. Pulling the fuse clears the code.
I referenced the connector(s) due to having seen this post before:
honda-tech.com/showthread.php?t=2860130
__________________
Old 09-04-2011, 11:52 AM
It may be the TCU again, as it shifts fine after a reset. You may already have seen this link before:
techauto.awardspace.com/transmission.html
Old 09-04-2011, 12:02 PM
Honda_Lady's Avatar
1992 Honda Accord
thanks for the link. i will check it out.
__________________
Old 09-09-2011, 12:46 AM
Honda_Lady's Avatar
1992 Honda Accord
ok one more question about this problem. if it was something other then the TCU would it reset it self twice by pulling the "back up" fuse? if it would do that how long would it take for it to fail a test again? mine takes almost a week to fail a test again. if it was something like shift solenoids wouldn't it fail a test sooner?
thanks again.
__________________
Old 09-09-2011, 01:23 AM
2005 Acura TSX
That is a tough question. If the mainshaft speed sensor (code 15) was bad, then the D4 light should turn on every time. Definitely check the electrical connector for any corrosion or damage to the wiring.
I would look on car-part.com to price used TCUs in junkyards by distance to see what one will cost you.
Before replacing the TCU, I would disconnect the battery and clean all ends of both battery cables. Once you do that, I would have the battery, alternator, and starter tested at a parts store. Charging/voltage problems could cause strange problems to pop up. Plus it is a free test.
Also, when the car acts up, check the codes again to see if you get the same codes.
How much transmission fluid did you have to add? Did you check the fluid with the engine turned off?
__________________
2005 Acura TSX MT
Old 09-09-2011, 02:08 AM
Honda_Lady's Avatar
1992 Honda Accord
it doesn't turn on every time. i will check those connectors anyway just to be safe.
i keep a close eye on what my battery terminals and wires look like. i replaced my battery not too long ago to put an Interstate in. it's worth getting it checked though.
when it came on the second time i checked the codes again and both times it was the same codes. it still hasn't come on again after resetting it the second time *knocks on wood*
i had to add maybe a total of 8oz. (that's combining each time i had to add some) could have been a little less or a little more. and yes i checked it with the car turned off.
__________________
Old 09-17-2011, 10:16 AM
It sounds for sure like a faulty TCU. I have a 92 Accord and i had the same problem W/O the fluid loss ? but i bought a TCU on ebay replaced it and the problem went away.
Reply
Tags
1992, 92, accord, code292accord, codes, honda, nawroconych, problem, problems, shift, shifting, solenoid, swiadectwa, tranny, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for HondaAccordforum.com content, comments, or advertising. HondaAccordforum.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse HondaAccordforum.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
Emails Backup
