Sponsored by:
Sponsored by:
Corrosion on negative battery terminal
Old 08-23-2007, 07:55 PM
accordfan222's Avatar
Default Corrosion on negative battery terminal
My accords battery negative terminal have always corrosion on it ( white powdery stuff.). I cleaned the terminal with contact cleaner and put some die-electric grease on it but still it does it. Is there any other chemical I can use to clean the terminal to protect the terminal Or need new battery. By the way battery is only 2 year old. Thanks for any suggestions.
Old 08-23-2007, 08:04 PM
smaglik's Avatar
Default RE: Corrosion on negative battery terminal
i would just clean it when it gets dirty....
also, please use a bigger font...
Old 08-23-2007, 09:41 PM
hondadude's Avatar
some batteries have a poor seal where the terminal comes thru the battery case that allows corrosive vapor to escape around the terminal.
Try laying a thick coat of grease around the terminal where it comes out of the battery case.
Old 08-24-2007, 03:40 PM
THANKS, I will try to put more grease on it.
barnbridge
07-16-2012 10:56 PM
mirandabell
07-10-2012 08:50 AM
ZinsMD
10-28-2011 04:16 PM
abhijitgp
10-02-2008 06:42 PM
00AccordLX5spd
01-02-2008 02:09 PM
Quick Reply: Corrosion on negative battery terminal
