Sponsored by:
Sponsored by:
97 Honda accord Brake Problem?
Old 06-15-2009, 11:09 AM
vcalos's Avatar
Talking 97 Honda accord Brake Problem?
I own a 97 accord lx 4 cyl. without abs. rotors on front and drums on rear.
My problem is that the brake pedal goes to the floor I already replace the following :
master cylinder, power brake booster,rear shoes and rear cylinders. I already bleed the whole system and still the same problem, I had a leaking proportioning valve which I also replace. Also I just check my front pads today and it seems that only one front wheel is braking because one pad is almost new and the other is almost metal could the caliper be my problem? any help will help thanks
Old 06-15-2009, 11:23 AM
00AccordLX5spd's Avatar
Registered User
Fist of all, was is a OEM Honda Master Cylinder? I have heard some aftermarket Master Cylinders have incorrect plunger lengths.
Second: I would definitely make sure the pads were equal. i.e. replace BOTH this time.
Old 06-15-2009, 11:24 AM
Did you bench-bleed the new master cylinder? You may still have air in the system.
Old 06-15-2009, 11:28 AM
Registered User
I assumed if he bled the entire system correclty, it would have still gotten that air out, regardless of bench bleeding. But it would take a lot longer to bleed the entire system if he did not bench bleed the MC.
--and yes...I do know the definition of "assume"
Old 06-15-2009, 01:53 PM
I've replaced MC without bench-bleeding. I bled the whole system (all 4 corners) and it LOOKED like all the air bubbles stopped coming out. But the brakes were very soft.
So I bled it again. I bled lots of fluid through all 4 corners, and eventually I got a bunch of additional air bubbles, then it was OK. The thing is, all that fluid you waste (without bubbles) makes you think you're finished.
SPD-2000-HONDA-ACCORD
03-29-2013 08:50 AM
Rabbit
09-14-2012 02:27 PM
MDawg
02-09-2012 05:17 PM
javelinman74
04-25-2010 09:04 PM
trickyvick
03-12-2006 02:01 AM
Quick Reply: 97 Honda accord Brake Problem?
