Sponsored by:
Sponsored by:
94 Accord Fuel Problem
Old 03-25-2008, 05:44 PM
habeeb89's Avatar
Default 94 Accord Fuel Problem
Hi,
I just recently had the code pulled from my 94 Accord EX Coupe, the CEL kept coming on and off int. The code that I got is the following:
43-2 Fuel Supply Over Lean
The guys at Pep Boys got me the code out for free, but wanted a arm and a leg just for a diagnostic fee to figure out what's wrong. My question is what might be causing this and what the soution is - maybe a vaccum leak in the fuel lines...??
Old 03-26-2008, 09:37 AM
habeeb89's Avatar
Default RE: 94 Accord Fuel Problem
Anyone?
Old 03-26-2008, 10:19 AM
Could be fuel pressure is wrong?
Could be plugged injector or crud causing it to dribble instead of spray?
Old 03-26-2008, 10:47 AM
MichaelT1960's Avatar
What about a partially clogged fuel filter? Was is ever changed?
My 94 Accord EX has never had it done...runs great...with 147750 miles on it. Probably should do it soon.....do not know.
Michael
Old 03-26-2008, 01:48 PM
habeeb89's Avatar
Thank you for the replies,
I have never gotten the fuel filter changed and the car has about 152,xxx on it, but I have never used cheap gasoline or driven in areas with a low octane offering. As the fuel injectors go, I usually put in a bottle of STP or any other brand fuel system cleaner about every 5,000 miles. I will try to use some Lucas Fuel System cleaner and see if it solves the problem.
Old 03-26-2008, 03:03 PM
falkore24's Avatar
FYI - octane has nothing to do with a fuel's clenliness or aptitude to leave deposits.
Old 03-26-2008, 05:49 PM
habeeb89's Avatar
I just put in a bottle of Lucas Fuel Injector Cleaner, hoping that it will help unblock and clean anything that might be in the injectors. If that doesn't do, I will probably have to pull the injectors and check them out.
How would I be able to check if there is a leak in the fuel lines or the fuel pressure is wrong, I mean, there is absolutely no gas leaking or the smell of it.
Old 03-26-2008, 06:42 PM
Chiovnidca's Avatar
ORIGINAL: habeeb89
Code 43? I'm not familiar with the -2 after it.
Does the car have any running problems along with the code? A rough idle or a loss of power?
Old 03-26-2008, 07:24 PM
habeeb89's Avatar
It's just code 42, the car seems to have some power loss at times, it hesitates a bit when going up-hill, but other than that performance wise nothing else is affected. The thing that is affected are the MPG's, went from 26 city to about 22 if I am lucky in the city.
rockhoundrob
04-11-2014 11:41 AM
Westjoe64
10-15-2012 12:11 PM
woody
09-15-2010 09:20 AM
fortyfootelf
01-22-2010 07:15 PM
kissbally78
01-18-2009 07:14 PM
Quick Reply: 94 Accord Fuel Problem
