94 Accord instrument cluster problem - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 11-08-2012, 09:49 AM
Default 94 Accord instrument cluster problem
Ok, so this problem just started today. I was driving to work and I noticed the tach and the speedo just drop to 0 (like car shut off) for a split sec. So i started watching it and id did it several times. I also heard an intermittent clicking noise from the right side of dash area. Car starts and runs fine. Any suggestions?
Old 11-08-2012, 11:41 AM
So there's no momentary interruption of engine power when this happens?
Old 11-08-2012, 11:47 AM
No loss of power.
Old 11-08-2012, 06:20 PM
If you have ABS, did it trip a light?
Those two gauges do share a common ground, did the temp or fuel level move as well. I'd inspect both battery cables, clean and tight at the battery. On the ground cable from the battery be sure the two points of contact (body and engine) are clean and tight. We can then get into the inside cabin ground for those two gauges.
Old 11-08-2012, 06:53 PM
The temp & fuel gauges are very damped so they move slowly. If the loss of ground was very short duration, the other gauges probably would not have had enough time to move.
Old 11-13-2012, 01:46 PM
Thanks for the replays. The ABS is not working in my Accord. So I pulled out the relay to stop the annoying vacuum noise it makes when I start the car. That is when I first noticed the problem. It did it again on Monday and the radio would also cut off, but no loss of engine power. Did not happen today.
Old 11-13-2012, 08:07 PM
ok......did you inspect the cables?
Put the relay back in and get the codes....I'll guess a code 1 - pump over run. From there check the fluid in the abs res - notice this is NOT the brake master res. Then Jim has a very nice write up in the DIY section for how to bleed the abs unit.
I'm going to stay with a bad ground for the one issue until verified.
Fixing the abs is a bonus
Reply
Thread Thread Starter Forum Replies Last Post
05 Accord Instrument Cluster Problem Rchristopher General Tech Help 0 10-16-2011 10:17 AM
Instrument Cluster 94/95/96 Accord CougarMark67XR7 Private 'Wanted' Classifieds 1 03-09-2008 08:32 PM
Instrument cluster 94 Accord LX CougarMark67XR7 Private 'Wanted' Classifieds 1 12-24-2007 01:08 AM
How to change 92 accord instrument cluster? imnoweirdo Appearance 0 01-29-2007 05:49 PM
pod cluster for instrument cluster marbro Appearance 5 05-20-2006 10:13 PM
Tags
1994, 94, 95, accord, cluster, dash, gauge, guage, honda, instrument, issue, lighting, tachometer, working, wy
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
