94 Accord LX: Surging idle - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 12-02-2011, 09:59 PM
Default 94 Accord LX: Surging idle
A couple of years back I had a problem with the idle. It would surge between 1,000 and 1,500 RPM. Vroom. Vroom.
I changed the plugs, distributor cap, and rotor and the problem vanished.
Almost two years to the day, the problem is back again. Vroom! Vroom!
I'm pretty sure that the plugs and distributor cap haven't gone bad in 25,000 miles considering the last ones were in for 70,000.
Any ideas?
Of course the weather is perfect for working on cars outside. :-(
Old 12-02-2011, 10:25 PM
Low coolant or a dirty IACV would be where I would start.
If coolant, where did it go, be sure to bleed the air out.
Old 12-02-2011, 10:46 PM
my '93 does that in spades during warm up only though.
1700 - 2300 rpms, lasts about a minute.
look forward to analysis and your solution.
Old 12-03-2011, 07:52 AM
poorman is spot on dirty IACV most times can be cleaned on car
Old 12-03-2011, 02:25 PM
Also look in the DIY section for a post by me about setting the BASE idle. Honda idle-control system is kinda touchy about how it's adjusted.
Old 12-11-2011, 04:47 PM
Had a chance today to go and see what the coolant is like. Radiator is full to the brim. Opened the bleed valve and coolant came right out.
I guess now I need to look at how to clean the idle control valve.
Old 12-12-2011, 07:34 PM
In the "Common DIY Threads" sticky at the top of this section is a "how to" clean the IAC, might as well inspect the FITV and then follow Jim's "Base idle" write up.
Old 12-12-2011, 11:35 PM
just hapend on mine there are lines that are vacumized check all vacum lines for leaks
Reply
Thread Thread Starter Forum Replies Last Post
1999 Accord LX 4cyl, surging idle (1000-2300rpm) amcdonal86 General Tech Help 30 05-08-2011 06:27 PM
Surging idle on a 2000 accord Honda hobby General Tech Help 3 09-15-2009 11:28 AM
surging idle 93 accord wjt General Tech Help 1 07-02-2007 02:15 PM
1992 Accord idle problems, surging wanderer63 General Tech Help 1 11-23-2005 02:17 AM
Accord v/6 surging at idle kwiggers General Tech Help 2 03-16-2005 08:29 PM
Tags
94, accord, cold, coolant, honda, hunting, idle, low, lx, lxi, problems, rpm, surge, surging, unstable
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
