94 Honda Accord crank pulley come loose with the nut tight
Got a 94 Honda Accord with a 4 cylinder engine in it , today all the belts flew off - started checking it out and the crank pulley was wobbling bad - the bolt holding it on is tight , but the crank pulley hole seems wore - i guess i need a new pulley ??? Is this a common problem on these ???
It's not too common; but, the crank pulley aka harmonic balancer pulley does sometimes needs to be replaced. It has rubber dampening material near the center of the pulley. Some people think it's all metal; but, it's not. It just looks like it's all metal because it is black.
When I use to have a 1995 Accord, the crank pulley started going bad and I had to replace it. On mines the wobble caused the pulley to start cutting into the plastic timing belt cover. That was many years ago.
have you removed the crank bolt and the pulley and chk it for damage??
jmattick
01-25-2011 06:37 PM
kegwad
06-22-2009 09:20 AM
