96 accord with turn signal short - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
LinkBack Thread Tools Search this Thread
Old 01-29-2011, 08:06 PM
Default 96 accord with turn signal short
Hello,
I'm trying to help my sister get her 96 accord working again. yesterday I tried to fix the turn signal issues. Checked the fuse (15A) under the hood, blown, replaced it. Checked the fuse (7.5A) under the dash, blown, replaced it. Turned the car on and turned the right blinker on works with out blowing either fuse. Changed from the right blinker to the left POP the fuse (7.5A) under the dash blew. Replaced it and tried again and again it popped.
Today I put a new 7.5A fuse in and tried to troubleshoot. Once again the right works and the left not. So I put another fuse in and tested the hazards switch and that blew the 15A fuse under the hood. All lights are working. Any thoughts or ideas on what to do?
Old 01-29-2011, 08:20 PM
The two components that could be the problem are the hazard switch or the turn signal/hazard relay.
Replace the fuses. Unplug the turn signal/hazard relay. Try turning on the hazard lights and/or the turn on the left turn signal. See if the fuse(s) blow. Let us know what happens.
Old 01-29-2011, 08:27 PM
Ok sounds good will do tomorrow
Old 01-30-2011, 06:01 PM
Well got her fixed. The driver side front turn signal wires where spliced together and that became bad and was shorting out blowing the fuse. Once I figured out the problem it was quicker to fix that then to put everything back together. But thank you PAhonda for you ideas. I will be coming back if i have any more problems.
Old 01-30-2011, 06:47 PM
Glad you figured it out. Wiring problems can be a pain to figure out. Shoddy electrical repairs make for even more frustration at times.
I try to solder wires together then use shrink wrap to waterproof the connection when possible.
Reply
Thread Thread Starter Forum Replies Last Post
turn signal in 03 accord Fat Ryan General Tech Help 17 10-22-2007 07:46 PM
88 accord turn signal bulb 88accord General Tech Help 4 11-29-2006 08:35 PM
88 accord turn signal 88accord General Tech Help 0 11-27-2006 09:09 PM
WTB: Stock 96 Accord Fog Lights and Green Turn Signal Bulbs Ntegra Private 'Wanted' Classifieds 0 10-09-2006 01:37 AM
95 Accord - clear tail light turn signal T07N Appearance 1 07-30-2006 02:40 AM
Tags
2000, 96, accord, blow, fuse, hazards, honda, lights, mount, panel, part, replacing, screw, signal, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
