97 Honda Accord Third Brake Light
[QUOTE=PAhonda;369877]The has to be a wiring or a connector problem. You said the wiring is brand new, so what wiring was replaced and why? Was a new or used harness used?
Testing for voltage with the bulb removed doesn't necessarily mean there isn't a wiring issue.
Here is a video on testing a third brake light. Next step is to do a voltage drop test. Do you know how to back-probe an electrical connector?
You could back-probe the ground wire, then connect the back-probe to ground to rule out a ground wire issue.
[/QUOTE
The entire wiring harness was replaced with brand new wires (every single wire running to the brake light) because I had this same issue a year ago. I will let you know when I do the back-probe.
MOTORBIKE
07-25-2012 06:57 PM
slammed accord
05-30-2012 09:53 PM
