Sponsored by:
Sponsored by:
98 accord D4 Light out and shifting problems
Old 11-13-2012, 01:56 PM
wilfrejavier27's Avatar
Default 98 accord D4 Light out and shifting problems
In my cluster D4 lights out and the cars doesn't shift smooth, all the others light up (P, R, N, D3, D2, D1). Sometimes it holds second gear and more longer then switch to the 3rd gear. It doesn't have a smooth gear switching. I really appreciate all your help. Thank You!!
Old 11-13-2012, 08:18 PM
Well you may not like my answer. First, many parts stores will scan for codes for free. Be sure to get the actual code from them (p0740 for example) and not their description of the issue. Cleaning a solenoid or two might solve the problem
Next, the auto trans in the 98-02 do not have a good rep.....they can last a long time with the issues you describe. If you ever have to get the trans rebuilt, be sure the proper upgrades are installed to help prevent the issue from coming back.
Old 11-13-2012, 08:54 PM
How's your transmission fluid? Have you changed it? Was it / Is it dirty? Did you use Honda fluid? Did you have it power-flushed or just drain & fill?
Old 11-13-2012, 11:25 PM
My transmission was rebuild a year ago. After that I found a a pressure sensor broke and I replace it but still doing the same thing.
Old 11-13-2012, 11:28 PM
OK I will do the scanner to see what codes does it have. Thank you for your help.
Jessicac1990
10-17-2012 06:15 AM
andydena27
05-18-2012 05:21 PM
blackbeauty97
10-12-2011 08:58 PM
Tyltong123
04-06-2008 01:06 AM
Quick Reply: 98 accord D4 Light out and shifting problems
