Go Back   Honda Accord Forum - Honda Accord Enthusiast Forums > General > General Tech Help
Sign in using an external account
Register Forgot Password?
Search
Welcome to the Honda Accord Forum - Honda Accord Enthusiast Forums.
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Reply
LinkBack Thread Tools Search this Thread
Old 01-21-2011, 10:27 PM
Exclamation 98 Accord Front End Noise
So over the past month there has been a grinding sound from the front end that has progressively gotten worse. The CVs, wheel bearings, and brakes, on both sides have been replaced. I have taken both the wheels off and had the car on jackstands and put it in gears and the noise sounds like it is coming from the center of the car, not from the hubs. When driving, it happens in all gears including just letting it go in neutral and also when braking. The car shifts in between gears no problem, but i have a feeling the problem lies within the transmission where the CVs go in. Any ideas or advice would be greatly appreciated.
1998 Accord LX 4DR 2.3L MT
This ad is not displayed to registered members.
Register your free account today and become a member on Honda Accord Forum!
Old 01-21-2011, 11:21 PM
2005 Acura TSX
A grinding sound is not good to hear especially if it is coming from the transmission.
Is the transmission full of fluid? Are there any metal shavings in the transmission fluid? When was the last time you changed the fluid? How many miles are on your car?
I rarely hear of accord manual transmissions failing, but there have been a couple of posts on here that I read about that happening. Not sure the best way to diagnose transmission problems.
__________________
2005 Acura TSX MT
Old 01-22-2011, 07:58 AM
Default Front end noise
I changed the fluid at 150k, there is 168k on it now. The fluid was black but no metal shavings or anything in it. I put in 3quarts of Honda MTF as recomended by the guys at my local honda dealer.
Old 01-22-2011, 08:32 AM
Are you sure you filled the transmission? I've heard of draining trans and putting replacement in differential; not good.
__________________
See you down the ROW
1994 Accord EX
2005 Toyota Matrix
2003 Acura MDX
2006 Acura TSX
Old 01-23-2011, 07:36 PM
In the manual, the differential is in the same shared case. There's no separate oil-fill for the differential cause it's inside the transmission.
Looking at the tranmission around the right-side axle, the drain plug is at 6-oclock and the fill plug is at 9-oclock. Is that where you filled? Not sure about 3 quarts, but you're supposed to fill until it just runs back out of the fill hole.
__________________
'05 Saab 9²x aero (RIP)
2 '07 Civics
'09 Saab 9³ss
'10 Saab 9³sc
Old 01-30-2011, 09:27 PM
Yeah i drained and filled using the spots described. Anyone know if there is a breakdown somewhere of my transmission. It really sounds like it is coming from right where the shaft goes in on that passenger side and i was wondering if maybe there was a bearing or something in there that might be bad.
98 Accord LX i4 2.3L SOHC VTEC MT
Old 01-31-2011, 11:45 AM
Here's the right side of the transmission case showing where the axle is located.
Click the image to open in full size.
Differential bearing is right there inside?
__________________
2 '07 Civics
'09 Saab 9³ss
'10 Saab 9³sc
Old 09-17-2011, 07:18 PM
I know it's been a while since you posted, but just curious what you found out. My 93 Accord with a M/T is doing the same thing. Any ideas?
Old 09-17-2011, 09:25 PM
1995 Honda Accord
Megatonrefugee
If the noise only happens on decell or neutral, it is most likely your pilot bearing/bushing located on the crankshaft end of the clutch assembly.
That diff bearing could be bad. Diff bearings usually only make noise upon accel, when the helical gears naturally try and push away from each other.
__________________
1995 F22B1(suspension mods)(SOLD)
1997 Grand Prix GTP
(intake, ported blower, 3.25" Pulley, 42.5# injectors, 75mm TB, 85mm MAF, Headers, 255lph fuel pump, worked heads, cammed, 3" downpipe, 2.5" catback, no cats, no egr, no evap)
Old 09-17-2011, 09:28 PM
1995 Honda Accord
Megatonrefugee
Ps my bad. There are two on either side. Does it happen on decel or accel? Or both?
Bad bearings won't cause gear clash, so that's why your not experencing harsh shifts.
__________________
1997 Grand Prix GTP
Reply
Tags
2011, 98, accord, end, front, grinding, honda, making, noise, passenger, scraping, side, sound, transmission, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for HondaAccordforum.com content, comments, or advertising. HondaAccordforum.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse HondaAccordforum.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
Emails Backup
