98 accord, no rev limiter? - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
LinkBack Thread Tools Search this Thread
Old 06-14-2011, 12:29 PM
Default 98 accord, no rev limiter?
I bought a 98 v6 accord recently, and this weekend was showing it off to friends, and ended up going to about 8.5-9k rpm.
Can anyone offer an explanation for this? Plan on taking it to the shop asap so maybe they'll be able to tell me.
Also how strong are the transmissions in these cars? How much to rebuild one if it went out?
Thanks.
Old 06-14-2011, 04:14 PM
The 98-02 V6 were known to have transmission problems. You would have to call around to find out how much a transmission shop would charge to rebuild the transmission.
You probably can save some money if you removed and installed the transmission. You would have to ask the shop about what they charge for that.
I don't know how the PCM handles the rev limit. I am not even sure if the PCM can be modified to change the rev limit.
Old 06-14-2011, 05:56 PM
The cost to have it rebuild is over 2 grands, also depending on your location.
Old 06-14-2011, 06:44 PM
is this a 5spd or automatic? if 5spd if you miss shift you can very well over rev the engine like you said.
automatic is impossible unless you put it in neutral and drop it
Old 06-14-2011, 07:43 PM
i guess it is possible since mine is an automatic..
Old 06-14-2011, 08:10 PM
98-02 Accord V6 only came with 4sp automatic.
Reply
Thread Thread Starter Forum Replies Last Post
99 accord 2.3 vtec hitting rev limiter at 4000 rpms? accord99 General Tech Help 3 06-22-2011 12:08 AM
93 Accord acts like hits rev limiter vdub90vw General Tech Help 13 04-01-2011 08:47 PM
speed limiter /rev limiter ? Driving me nuts General Tech Help 4 12-01-2008 08:17 PM
REV LIMITER?????? jaeal General Tech Help 2 05-12-2007 12:46 PM
rev limiter/electronic governor dinzer Engine & Internal 9 10-18-2005 11:27 AM
Tags
1998, 94, 98, 9802, accord, accordno, eliminate, engine, honda, limit, limiter, remove, rev, speed, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
