What part is this called and how do I change it? Brake Line
Old 06-21-2011, 06:05 PM
letsmakedonuts's Avatar
Default What part is this called and how do I change it? Brake Line
I have some leakage! I need to know the name of this part. If you can't tell in the picture it is by the rear driver side wheel. Brake fluid is leaking out of it. 98 Accord v6 ex coupe
Old 06-21-2011, 10:39 PM
that would the outer tie rod, if its the one closer to the rotor, if its attached to the frame? its an idler arm
Old 06-22-2011, 12:11 AM
ronjr8102's Avatar
if that is brake fluid then the part in the pic is not the problem. That part doesnt contain brake fluid. Clean that part, caliper and the area around the brake hose w/ degreaser and press the brake pedal to try to get the leak to start up again and see when it is coming from. Could be caliper piston boot, banjo nut washer or hole on brake line.
Old 06-22-2011, 01:05 AM
Exclamation
Good answer here..I think that you do what he said here and then look for new leakage..
plantheaction
10-17-2013 06:42 PM
rocus
12-05-2012 09:37 PM
BillsWagon
10-26-2011 12:06 PM
Boo65
11-18-2010 10:10 AM
ChicagoBob123
09-18-2010 09:36 PM
Quick Reply: What part is this called and how do I change it? Brake Line
