99 Accord EX Engine Cranks but won't start
Old 07-31-2006, 12:50 AM
thomks
Default 99 Accord EX Engine Cranks but won't start
We have a 99 Accord EX. On occasion, the engine will crank but not start. If you let the car sit about 5 minutes or so, it will start. It doesn't do this all the time, just periodically. Any suggestions?
Old 07-31-2006, 12:55 AM
Default RE: 99 Accord EX Engine Cranks but won't start
does it act like its about to start then dies, and just wont turn over after that?
Old 07-31-2006, 01:01 AM
thomks
No, it just continually acts like it's going to start, but never does.
Old 07-31-2006, 01:10 AM
im having kinda the same problem along with many other ones. lol but there are alot of problems that have solutions on the site if you take some time to look over the site you might be able to find the solution. some times its the starter switch, on my car i know its under the dash in a aluminum box, but on yours im not sure. sorry if im not much help but im sure someone will be along soon to help you out more. it may take a day or so but so far ive had some real good suggestions on what to do with my problems.
Old 07-31-2006, 01:42 AM
YeuEmMaiMai's Avatar
check your fuel pump and fuel pressure regulator. Check to see if you are getting spark. If it was your immobilizer your car would not crank at all.
Old 07-31-2006, 09:18 AM
Chiovnidca's Avatar
ORIGINAL: YeuEmMaiMai]
It would crank, just wouldn't start. The immobi system turns off the fuel. If it was the problem the immobilizer light on the dash would be flashing.
Old 07-31-2006, 12:11 PM
deserthonda's Avatar
when car does not start you need to diagnose if it is lack of spark or lack of fuel.........
https://www.hondaaccordforum.com/CAR...m_22438/tm.htm
Old 07-31-2006, 05:14 PM
Treaddirt's Avatar
My 98 Accord has not started (cranked, spark at the plugs, power throughout the car, and getting fuel) twice the last 3 weeks when it had been parked for a while and hot (80's) outside. After about 10 min. the car would start I'm going to replace the main relay as suggested by Deserthonda's reply which included a link to a very helpful web site.
Good luck.
Old 08-15-2006, 06:43 PM
Treaddirt's Avatar
Ok it's been almost 4 weeks now with the new Main Relay and no problems starting it in hot weather after sitting all day with the windows rolled up. Good luck...........
Hondataco
01-31-2014 10:14 AM
maddogtheman329
03-26-2012 03:15 PM
Spectre
01-17-2010 06:08 PM
jjrho
05-04-2008 10:22 PM
LiquidR1
09-02-2007 09:26 PM
Quick Reply: 99 Accord EX Engine Cranks but won't start
