Changing pwr steering fluid
Old Mar 19, 2007 | 09:21 PM
19Accord97
Default Changing pwr steering fluid
Hey!
I am just curious how to change the power steering fluid, if its possible w/ basica tools and how much you'll need and such! Thanks
Old Mar 19, 2007 | 11:47 PM
cheggie's Avatar
Default RE: Changing pwr steering fluid
To drain the fluid completely, you can disconnect the return hose (the one without crimped fittings) and use a gallon jug as a catch can. If you remove the p/s belt you can turn the p/s pump pulley by hand in the normal direction of rotation. This will pump the fluid out, just be sure to add some new fluid to the reservoir so it continues to push the old stuff out. When the fluid from the return line looks new, you're pretty much done.
Starting the car to pump the fluid out would probably require quite a bit of coordination to prevent running the reservoir dry - not to mention what would happen if your attention was divertedfrom the stream of p/s fluid spewing into the catch can. It could be done, it just might get messy. Alternately, if you disable the fuel or ignition system 20 seconds of starter cranking would probably do it. Just don't run the stater too long at one time.
Old Mar 20, 2007 | 02:49 AM
Lift the front of the car on stands, good & solid.
Disconnect a hose down low, on my '98 there's a hose going out to a cooler tube in front of the radiator.If possible, get a hose to extend this out to a bucket. Otherwise it'll make a mess...
Have someone start the engine. PS fluid will run out to the bucket. Turn the steering lock-to-lock a couple times to drain the fluid out of the rack. Stop the engine right away.
Take out the reservoir & clean it. There's a fine screen down in the reservoir that can get dirty.
Put back the reservoir, hook up all the tubing, fill the reservoir. Start the engine just long enough to turn the steering lock-to-lock twice. Now the fluid will be all foamy. Add fluid & wait (hour?) for the foam to settle. Repeat a couple times. Eventually the fluid willquit foaming.
Old Mar 20, 2007 | 05:14 PM
MALSR's Avatar
Use only honda power steering fluid
nyaccodguy
Mar 17, 2015 06:38 PM
rics06
Jun 4, 2013 04:44 PM
Pauls95
May 15, 2007 07:06 PM
zoominhuman
Mar 23, 2007 10:29 PM
cbudgo
Mar 3, 2007 05:49 PM
