Sponsored by:
Sponsored by:
Ac compressor clicking on and off.
Old 07-26-2016, 06:16 PM
Lanaue's Avatar
Default Ac compressor clicking on and off.
So my nephew has an 08 Accord Coupe and his Ac stopped working. I assumed it was low but when I hooked up the gauge to the low side it read 120.I hear the compressor and fans engage ever 5-7 seconds.
Old 07-27-2016, 03:10 PM
Rapid cycling can have several causes, but most frequent is low charge. A static pressure level of 120 psi does not accurately indicate charge level. You need to observe low side pressure when system is cycling. If pressure is going below perhaps 15 psi, then low pressure switch opens, disengaging compressor clutch.
Fix is to charge to correct level. See following video link for help.
If you have no experience w/ AC work, better to let someone w/ experience charge your system.
Other reasons for rapid cycling are excessively high pressure and blockage in system.
Old 07-27-2016, 06:45 PM
Lanaue's Avatar
Thanks Tex, I did put that my gauge was reading 120 on the low side.So I had it drained and refilled,by the dealer.It worked fine for about an hour then blew warm again.
Old 07-27-2016, 07:44 PM
Are you using a gauge similar to the video that can connect to both ports? Are you testing with the engine running and the a/c turned on?
ak474u
05-04-2015 11:15 PM
jhaschke
01-02-2012 09:18 AM
lee_vh
02-23-2009 07:07 AM
stokesdope
08-24-2005 07:32 PM
Quick Reply: Ac compressor clicking on and off.
