Accord 2006: hard to replace driver side low beam bulb
Old 08-05-2006, 01:28 AM
mngantung
Default Accord 2006: hard to replace driver side low beam bulb
I have a 2006 accord 4 door. I found out when replacing my accord low beam bulb on the driver side, I have to cut part of the plastic of the bulb to get it in. Is that a defect on the socket/housing itself? Can I have the dealer replace the housing?
Old 08-05-2006, 01:37 AM
Chiovnidca's Avatar
Default RE: Accord 2006: hard to replace driver side low beam bulb
ORIGINAL: mngantung
You shouldn't have to. Got the right bulb? Should just stick it in there and give it a little twist.
Old 08-05-2006, 01:39 AM
mngantung
I have the right bulb with no problem on passengger side, but have problem with the driver side. When I opened the bulb from the honda original manufacturer, the plastic on the bulb has been broken in order to fit on the passenger side. Thanks.
Old 08-05-2006, 02:46 AM
deserthonda's Avatar
why are you doing any work at all on your car ?? it is fully under warranty.........Unless you are planning on installing different bulbs , have the dealer do all the work on it,,
Old 08-05-2006, 02:22 PM
Chiovnidca's Avatar
ORIGINAL: mngantung
If it's broken take it back.
hallstevenson
08-08-2013 11:27 AM
jarede7
11-26-2008 10:14 AM
kouken
11-11-2007 06:48 PM
kouken
11-08-2007 08:39 AM
LotusDriven
07-20-2007 02:07 PM
Quick Reply: Accord 2006: hard to replace driver side low beam bulb
